Well, I look forward to seeing it in operation, but you'll excuse me if I don't hold my breath.
Do not attempt to build this engine.
It will not work.
Think conceptually: The boiler is high pressure, the condenser is low pressure. The resultant differential pressure between the boiler and condenser forces the stem through the engine. Unlike compressed air, the high heat capacity of steam maintains elevated pressures during work extraction.
Without a differential pressure, you simply cannot extract mechanical power from steam. Consider a traditional boiler design, where a 150 psig boiler feeds a vented condenser. The boiler creates a differential pressure across the steam engine of 150 psig. Again, the pressure is the driving force of work extraction. The high heat capacity of steam slows the drop in pressure during work extraction which is why water is the medium of choice for power plants, and not air. In the proposed design, you dont begin to make steam until you draw vacuum on the boiler, which means that the boiler and condenser are operating at nearly the same pressure. The differential pressure across the steam engine will be practically nonexistent, and so will the power extraction.
There is another critical design flaw, which Tin Falcon pointed out specifically:
Saturated water (212 degrees F, atmospheric pressure) contains 180.12 BTU of energy per pound mass. If you port the saturated water into an evaporation chamber, and draw a vacuum on it equal to 5 psia, heres what will happen: Approximately 27.7% of each pound of water that enters the evaporation chamber will flash into steam. The steam will have a temperature of 162.18 degrees F, and a specific volume of 73.525 cubic feet per pound-mass.
The remaining 72.3% of each pound of liquid water that enters the evaporation chamber will reduce in temperature to 162.18 degrees F, and will remain inside the chamber. This water must go somewhere, or youll fill up the chamber. As designed, the liquid water will be drawn through the steam engine, with no work output.
If you port the saturated water into an evaporation chamber, and draw a vacuum on it equal to 1 psia, heres what will happen: Approximately 61.3% of each pound of water that enters the evaporation chamber will flash into steam. The steam will have a temperature of 101.69 degrees F, and aspecific volume of 333.49 cubic feet per pound-mass.
The remaining 38.7% of each pound of liquid water that enters the evaporation chamber will reduce in temperature to 101.69 degrees F, and will remain inside the chamber. Again, this water must go somewhere, or youll fill up the chamber. As designed, the liquid water will be drawn through the steam engine, with no work output.
Smithdoor, whoever told you that this engine has been in use for over 100 years told you a lie.
Additional design consideration: the available solar flux from the sun is about 1-kw per square meter (this is for a bright sunny day). If you assume a reasonable thermodynamic efficiency for the solar panel of 40%, and a reasonable 5% thermodynamic efficiency for a piston-steam engine operating at low temperatures, youll require just over 37 square meters of solar panels per one mechanical horsepower out (again, that's assuming a bright sunny day). Point being - there is a reason the solar industry is failing in a disastrous fashion. :fan:
You make good sense. Am doubtful solar heaters will raise enough BTU to get reasonable steam pressure/volume to spin a small recip steam engine.
The solar industry is very successful, where countries have wholeheartedly promoted it.
Solar cannot replace coal, oil, and/or nuclear - theres simply isn't enough energy density in solar power.
Consider a hypothetical 70-horsepower all solar-powered electric car. <snip> Thus to drive a 70 horsepower car under sun power, youll need a solar panel sized 536 square meters. On a car, that would be a rectangle panel six feet wide, and 107 feet long (not possible). Youll also need to double the cell area for driving on overcast days. And you cant drive at night. Thus a battery system could be used, however now the cell area really needs to be increased in order to charge the battery while also driving the car.
To really drive home the point on how "not-good" solar is, lets look at the energy requirements needed to get US cars off of gasoline (which is the ultimate goal of the green movement). <snip> On a bright sunny day, assuming a solar panel output of 140 watts per square meter, youd need a solar panel sized 2,155 square miles which is about 1000 square miles larger than the entire state of Rhode Island. . .
...and *this* is what the problem is.nor can we produce enough batteries to store the charge.
Sunworksco, I know you dont like reading what I posted. Nonetheless, please check my numbers, and tell me where I'm wrong. . . . ?
as far as solving the energy crisis we could invest in good old steam power (created by nuclear reactors) and do what we can with solar with grid tie in inverters. if nothing else it'll ease the load in peak hours and reduce summer blackouts.
i think solar steam could work but maybe not in a low pressure system. with parabolic reflectors you can create quite high temperatures and could maybe run a turbine. as cool as a piston steam engine would be chugging away in the corner of the shop even if you got high pressure steam from sunlight lets be honest the noise would eventually get to you.
Hi Dave SmithDoor,
Out of interest, how big do you think your low pressure steam engine will need to be, and what will it cost to make, for you to power your shop with it?
You did say the power would be "free", of course that's only after you've shelled out the cash to make it - so what will it cost? I'm interested to see the economics and payback on it.
