- Aug 25, 2007
- 3,890
- 715
I've been thinking about this for some time now and have done a few preliminary drawings. So, I think my next engine project will be a somewhat stylized model of a Bessemer 2 stroke oil field engine. I want to get it as close to the real deal as I can without using any castings.
At this point I'm planning on a 1.25" x 1.75" bore and stroke. The flywheel(s) will be a little under 9" diameter and the cylinder will be made from a piece of DOM tubing, 4" long x 2" diameter. It will be water cooled and I want to try to make it fired with a hot tube.
If I can make this work, it will be a pretty simple engine to build. There won't be any gears, no valves, and no ignition, although I may have to fall back on an ignition system if I can't get the hot tube to work. It should also be an easier hot tube engine to make since it won't require an injector or injector pump. I plan to use a vapor fuel tank so I won't need a carburetor.
Here is a video of the engine that is my inspiration:
[ame]http://www.youtube.com/watch?v=_9QbtZNOKX0&feature=autoplay&list=ULiY3F-KIcuws&playnext=1[/ame]
This model was designed by John Burns and the castings are supposedly still sold by Robert Horner although I was never able to reach the latter. I did reach John Burns and he gave me a little bit of information about his design, but he no longer has any financial interest in the plans or castings. At any rate, I believe the Burns model is larger than I want to build and the castings are probably priced at a great deal more than I would want to spend. Besides, designing them is half the fun!
I hope to start making chips in the next few days although a 10 day vacation scheduled for the end of the month will probably delay much progress on the engine.
Chuck
Chuck
