skyline1
- Aug 6, 2012
- 441
- 150
Hi Luke
Something like this might do the job High Temperature 0.3mm² to 6mm² Fibreglass Wire Appliance Cable HIGH TEMP 250℃ | eBay
You can get the stuff in pretty fine gauges down to 0.3mm sq which has a rating of about 3 amps and is available in black so you wont even have to paint it. It has an O.D. of just under 2mm so it should look somewhere near scale.
Unfortunately you may have to get it direct from China so it might take a little while to get to you. A quick search of EBay will often turn up a supplier with a U.K. warehouse though. Just search for High Temperature Wire. You want the glass fiber stuff not silicone wire.
And these Solid Brass Wing Nut M3 M4 M5 M6 M8 M10 M12 | eBay should make some nice scale terminals with some M3 screws they are proper old school "Mickey Mouse" ones not the modern shape.
BTW if your figures are correct at 1000 R.P.M. 24 Volts x 3.6 A is 86.4 Watts which is quite an output power, this would light up an awful lot of LEDs
Best Regards Mark
Best Regards Mark
