Hi all, not sure if this is in the correct forum here as its not an engine but it is made from castings and it realy only works when coupled with an engine.
Im sure some of you will find it interesting enougth to follow along anyway.
I have had some questions regarding the making of this model so il record a full build log with plenty of photos to show you how i make this model.
I have already recorded the design process of the model in the 'work in progress' thread if you are interested in that.
This log will just be a record of the build and machining steps i use to finish the model.
This is how the finished model looks..
The generator is designed for lower speeds around 500 RPM this is relativly slow when compared to the the available DC dynamo model kits available that require 4000+ rpm.
This is how the kit of parts looks it includes all castings, barstock, fittings, wireing, drawings, pre made coils and a plastic 3d printed stator ring.
I start with the base casting first this just requires the mounting points milling level.
A simple clamp setup is used to hold the part on the milling machine. Forst i machined the bearing mount points then rearange the clamp and lower the spindle 20mm to cut the lower stator mounting points.
Thats all for today i will get stuck into this tomorrow and record the progess.
Best regards.
Luke.
Best regards.
Luke.
