Making Sparks: Making Nano Sparks movie
Finally I'm making sparks and 1 thing is for certain my jury-rigged timing light sucks, I'll make a better one. I made a slow -mo movie but, it kind of sucks also and had to use my editing software to look at it frame by frame. It showed that on one magnet I'm off by about 3 degrees and the other is off by 5. I can get rid of this by adjusting the Hall's location in software and of course if I had only 1 magnet it would be easier. In the movie the sparks quits every now and then but, it only did it in the movie, go figure. Otherwise it was steady as a rock. Also using a longer dwell gave a better spark and it was nice to see that using a 4msec dwell I could get up to 11,000 RPM but, it starts to cut out @11,500 RPM. There is a noticeable harmonic with the LS2 coil @6,500 RPM where the spark dies down a little but, that's 1,000 RPM higher than the old GM-HEI 4 wire and not as bad. I don't know the spark strength yet, I'll wait until I have a safer setup for that. One thing I'm really happy about is the noise from the coil. It's only about 8 volts negative and about 11 volts positive so, this shouldn't be to hard to cleanup. Something strange, when I turn the motor off and let it stop it will keep firing at a rate of a heart beat. This stops if I push the reset button on the Nano. This only shows up when the motor is not turning, something else to fix.
So it seems that I have all the core hardware prototyped and I can start on the PC software for programming the Nano. I have a board designed already and will order them most likely at the end of next month. I'm using an Infineon IPP25N06S3L-22 OptiMOS-T2 Power-Transistor to drive the coil trigger signal, it stays cooler than the Nano. And of course like a lot of my stuff it's obsolete, I'll have to find a newer alternate. Maybe I should have just went with the 2N7000 FETs like I was going to do, I will in fact. I'm going to be using this setup as basis for another ignition for my race car which will be a distributorless ignition for my Olds 455. Well the cam sync is actually a Ford Mustang (5.0L) cam pulser that also drives the oil pump.
So I'm vary pleased with the way things have worked out so far. More on the video, the actual sparks at idle @550 RPM looked both blueish and orange to me but, on the video they were just orangish in colour, blue filter on my phone. Also I apologize for the spark cutting out, I kept hitting some wires that made the spark cutout. The Nano and LEDS only drew 30ma which was nice, not sure what the coil drew, I'll check later. So I have some filtering to do like pull-ups or pull-downs on unused pins an such, also maybe a snubber circuit, we'll see.
Ray
Ray
