Swifty
Can give you some Chris.
On closer inspection there doesn't seem to be much point in 'growing' the CP. It's cracked.
Hi Jack, to answer your question over compressing would not do this to your rod. I wonder if your cylinder is not slightly out of alignment with your crank. This would cause a ton of stress on the pivot points and that's what you're gettingCheck out the bend in the conrod big-end. I'm obviously doing something wrong. Could over-compressing the engine cause the conrod to bend?
Hi Gerard,
Thanks for the compliments. Just today I tried to get the other Midge running. It's been sitting on the bench in my workshop waiting for me to find the motivation to try and get it running again. It needs to have the compression screw wound in a long way for it to fire. It will then start and run very roughly. If I back the screw out it stops running.
I also think there may be something wrong with my carb. The engine will run (roughly) with the needle jet removed and my thumb placed over the hole that the jet screws into. I have no idea what that means.
Here's a video of it running. I hope that somebody will be able to diagnose the problem for me.
Your Midge is running under-compressed and quite rich-you need to wind the compression screw in further still yet.
amazing ! thanks for sharing! i´m new here and i want to start my first build.
