JAndrew
- Aug 9, 2013
- 113
- 21
HMEM,
I'm milling quite a few 1/4" wide grooves in carbon steel to a depth of .315". I'm using a nice carbide end mill and taking passes of .020" at a time. I've been running the spindle at 1200 rpm but the part is getting pretty hot by the end of milling one groove. I don't have a coolant system and probably won't for a while as I work pretty slow anyway.
I know the tool can take much higher RPM's so my question is: Would cranking the mill up to 5200rpm (it's maximum) help to cut down the heat?
The passes would take less time as I could feed faster but there will be more friction at a higher RPM too...? Which way would win out?
Things I should probably already know...but don't.
Thanks,
-J.Andrew
Thanks,
-J.Andrew
