I burn diesel in my foundry furnace, and it burns cleanly (cleanly being a relative term), with no smoke at all.
I had some concerns about fumes from burning diesel, but it is not like I stand around and inhale the exhaust or anything.
But everyone should remember that if drive your car down the expressway in the US (or perhaps anywhere), you are breathing in tons of exhaust from the diesel engines that are in the trucks all around you.
Nobody seems to be concerned about that.
I did notice that the indoor air quality at the 2019 NAMES show was very bad.
They would announce over the loudspeaker every 30 minutes or so for everyone to turn off their engines so the smoke could clear, and they would partially raise an overhead door for a few minutes.
The combination of all the exotic fuels and fuel/oil blends being burned in all of the internal combustion engines affected my lungs and breathing for days after the show.
There is no place at NAMES to get away from the fumes. The whole building is a "heavy smoking" section.
I am not complaining, it was a great show, but that was a toxic mix of partially burned fuel coming out of all those high-revving IC engines.
They need to keep a roll-up door open at all times at NAMES.
All that being said, I think the exhaust from a single scale model engine is negligible compared to any fumes you will breathe by just driving down the expressway.
So while I fully believe in using great caution with material data sheets for every foundry product I use, and I adhere to every safety warning about foundry products, I think with a single small scale engine, we need to realize that only a tiny amount of fumes are produced.
You can easily die from drinking too much water, but nobody is sounding the alarm about water and how toxic it can be.
Common sense must dictate safety.
I think if you did an analysis on a hamburger, or a grilled steak, or any fried food, you would be shocked at the number of potential carcenogenic things are in those (I don't often grille out for that reason, and I don't eat fried food often either, because I don't want to look like the Goodyear blimp).
We should all be safe in this hobby, but in a reasonable and logical way, with an appropriate amount of caution to match a corresponding danger.
Edit:
The trend these days is to go overboard about safety.
One guy from Australia told a story on a casting forum a few years ago about how his local council decided that all foundry sand was a deadly toxin that destroyed the lungs. They were planning on banning all foundries and all foundry sand.
The guy went to the next council meeting, and spoke at the podium, and said "You are going to have a very hard time banning sand because our city is on the coast, and 100 yards from here are miles and miles of beaches with the very same sand as you are trying to ban".
There is too much fear-mongering these days about seemingly everything.
Awareness is one thing; obsessing about the toxicity of every substance on the earth is not necessarily reality.
Edit:
