It's not a matter of cheap, but it's really hard to buy and seems seems more toxic than if you just use keroseneRunning the dieselengine with ether added in kerosene is not cheap fuel economy.
Looks like it runs very happily on kerosene! I'm going to venture a guess that it would also run just fine on #2 diesel ... and might even run on a range of other oils as well. My dad talks about engines that they had to start on one specific fuel, but then could switch over to just about anything flammable to run. Maybe that would be true for this engine?
In any case, whether it "only" ever runs on kerosene, I am very impressed. The key is that you successfully mastered the pump and injector!
and warmed the cylinder head with a torch for about 10 seconds and : RUN
Pretty much every car or utility sized modern diesel uses some kind of glowplug to aid cold starting, so it's no surprise that minh-thanh's model needs a bit of preheating as well.How big is the compression ratio in your engine? At higher compression ratio is developing higher temperature.
If the high compression ratio is high enough, then there is the problem of good atomization of the fuel for the engine to be able to start up without heating the cylinder head. By heating the cylinder head, you make the fuel evaporate and ignite more easily at start-up. Injection timing also affects the engine to be able to start easily and without creating engine knocking during normal operation.
Kerosene Heating Fuel 1 Litre | Sydney SolventsYou might find kero is easier to find in your country than others mate. For example kero is quite expensive over here in Australia as it’s only available in 1 or 2 litre bottles. It used to be available at the bowser in service stations years ago but it’s not used all that much here anymore.
Makes me wonder if a normal glow plug from a model aeroplane engine would a work for starting a model diesel.
theoretically : about 15 - 1
Increase the compression ratio...I know, but I wasn't planning on using kerosene at first, kerosene was just a way I wanted to find out what the engine could be....
What is the fuel used ? and are you sure ?Find Hansen diesel engine has injection begins at 40-45.
Pretty much every full sized modern diesel uses some kind of glowplug to aid cold starting, so it's no surprise that minh-thanh's model needs a bit of preheating as well.
I reckon it would, as that is the basis of every hot-spot device since blow-lamp heated hot bulbs....Pretty much every full sized modern diesel uses some kind of glowplug to aid cold starting, so it's no surprise that minh-thanh's model needs a bit of preheating as well.
Let us not forget that Mr Ricardo developed the "pre-combustion chamber, or Indirect injection" to overcome problems of direct injection and associated difficulties.Increase the compression ratio one step up and try until it is able to ignite the fuel of its own heat from compression. Find Hansen diesel engine has a compression ratio of 20: 1 and injection begins at 40-45. You must test how far the engine can inject before TDC without getting an ignition knock. Drops of fuel need time to be heated until it becomes self-igniting and gets full combustion just before TDC.
I should correct that to 'car and utility size' diesel. I guess large displacement diesels have less need for preheating due to surface area: volume differences.Please provide a reference for your assertion.
To my knowledge modern semis don't have any kind of glow plugs.
Now guys that run in northern climes do have coolant heaters but that's a different thing all together!
