Mery Explosive Engine
In the cold hard light of the next day , I have found that the covers to the explosion chambers leak, the flywheel needs better securing to the crank, the inlet valve springs are too strong, cylinder oiler needs a redesign ,and on and on, but yes, a start on the first day of trying seems to erase the memory of previous engines that took forever to cough into life. Still much to do before I sign off on this one though. Colin
Even so, it sounds wonderful,not noisy and looks to run extremely well
That is a lovely looking and running engine! Great work.
Is it to your own design, or do you have plans / castings kit?
Do you have any details of the build? Pics/videos etc.
I'd love to get a hold of some plans if you have some available, or point to a vendor.
Well done again! Beautiful craftmanship!
Marvin: this is a kit from Martin Models in Oregon I received it in the mail in Feb 2022 and began the build in March. The first things to do were to make a boring bar and table to fit my12x36 lathe in order to bore the main housing and cylinder. There are good drawings with this kit but absolutely no "hand holding" directions on how to go about the build. You must figure out for yourself. I just recently learned how to post pictures and although I did not make notes of of the build I did take a few pictures of set ups and procedures along the way. If there is interest I will post a couple of those pics and comment on what I'm doing . It may or may not be of help to someone who wants to make this unusual 6 stroke explosive engine. Colin
    6.2 MB
    6.4 MB
There are 3 machined tabs on the frame that I assumed were made to parallel the bore, NEVER assume. All set ups were made with this as datum. The end result is that the bore "slopes" approx. .015 toward the crank end. This did not appear to be a major disaster at this time. Further work on the frame proved this wrong. Later set up to locate the main bearing (there is a Joe Pie Video explaining this, I don't know how to link) resulted in there being very little material to thread for main bearing bolts. I put 4 extra 4-40 studs and nuts on each main cap to spread the load.
    5 MB
    5.7 MB
    4.3 MB
    6.1 MB
    4.6 MB
Picture 1041 shows the set up to locate the centre line of the crankshaft. I made a plywood fixture to hold the frame at 45 deg. to machine the bearing seats. Take time to set fixture accurately to all 3 axis. 54&56 show set up used to drill and bore for main bearings and camshaft. At this point the error in initial set up became really bothersome. There is not a lot of extra "meat" in the boss for the camshaft. Drawing calls for 32P gears of 50 and150 teeth and pitch circle of 3.125". Because the crank sits lower in the frame, this meant that the camshaft would be to far off centre to look right. I chose to make the gears 32P 48&144 teeth ,still a 3-1 ratio but with centre to centre distance of 3.0" which fit the casting better. This "fix" ended the compounding of errors related to the initial set-up. The engine looks and runs fine, unless someone counts the teeth or it sits next to another Mery, no one would ever know.
Oops, I told you. Can you keep a secret?
    6.5 MB
    5.9 MB
    6.3 MB
    5.2 MB
    5.6 MB
    3.7 MB
    4.2 MB
    6.7 MB
    5.1 MB
I prefer the look of crankshaft with counterweights rather than plain "blocks" as called out. Cut two discs of appropriate size then set up on rotary table to add features as desired. Shafts are 1/2" TGP steel .#1064 shows spacer blocks to hold parts together for silver soldering. Once soldered and cleaned up, I drilled and pinned the main shafts to the webs. They are straight1/8 tool steel in reamed .126 holes pressed in with green Loctite. Cut out centre of main shaft and mill flat.
    5.4 MB
    5.1 MB
    4.4 MB
    6.4 MB
    5.9 MB
Pics 72&73 show the crosshead and conrod. Must have forgotten to take pics of these while making,. The conrod is straight forward turning a taper between two square shoulders. The crosshead is nerve wracking! The bronze shoes on the cross head are each held in place with a single 4-40 stud and nut, only 3 threads engaged. Then the assembly is centered and held on the 1/4 " piston rod while turning the shoes to fit the 1 1/2" bore. With every interrupted cut rotation I expected disaster, but all worked out O.K. Fly wheel is set up on a faceplate but even with a12x36 lathe the compound had to be reversed to get the tool out far enough to machine the rim The finished flywheel on the frame mounted on the base spins the crank nicely pushing the crosshead back and forth.
    6 MB
    6 MB
    6.3 MB
    6.4 MB
    6.2 MB
Set up to machine the faces for the inlet (explosion) chambers to use as a datum to bore the cylinder barrel. There are protrusions inside the barrel to locate the liner so this is an interrupted cut taking many fine cut passes. 1097 shows turning the O.D. of the liner to be a shrink fit(.002) in the barrel .After shrinking the parts together a pressure test of the water jacket revealed 2 blow holes in the casting. As I had many hours invested in this part I chose to repair rather than replace. I did contact Martin Models, Gary wished me luck with the repair and commented that sometimes problems don't show up until later in manufacture. I followed the direction of the holes and drilled/tapped for 6-32 brass screws Loctited in place. This fixed the problem. 1101 shows the barrel set up again to machine to length, I used a fly-cutter to do this.
    5 MB
    5.1 MB
    5.1 MB
    5.5 MB
    5 MB
    5.1 MB
    5.2 MB
