Kolten etal,
Copper is a very gassy metal to pour. You can degas with various things like chlorine and other very nasty chemicals. The gas can lead to a casting that looks like a "bran muffin". I had to wrestle with myself for a while before I told you this. Please be VERY careful when using chemicals of any kind. Remember, ventillationventillationventillation. They can make your life a living hell.
That said, there are two ways to keep gas out of your castings. First of all you should be using a cover flux, Glass works great for this. It melts covering the metal and keeps the air away from it. When I was a teenager and hanging around a brass foundry in Manasquan, N.J. they used to use their old beer bottles, yes industry was beer powered at one time. Try this and see how it works.
As far as your temp. goes, Tin Falcon was right about using charcoal when this first started. If you can melt iron with charcoal you can certainly melt copper with it. It sounds to me like you need more air, go right to the shop vac and see what that does. But make sure it has a waste gate on it to let some air out before it gets to the furnace if need be. But remember you will burn more charcoal and if you are using grocery store briquets STOP IT. You need to use real harwood charcoal. Thats why there is so many plans out there to make your own charcoal. Grocery store briquetts are usually 50% binder...like bentonite aka clay.
As far as what you are melting the first choice would be industry supplied metal, meaning the right alloy for the right job. The next is scrap yard furnished CLEAN copper pipe and wire. Do not melt copper electrical fittings, as a lot of these are beryllium copper and the smoke from this metal is poisonous. The same goes for old plumbing fittings, alot of them are high in lead, and if they are newer they are probably from china...need I say more?
Remember Silicon Bronze will get almost anything done you need and it is excellent to work with, very low drossing. Alum., and almost all copper alloys and copper itself is high drossing.
Health Tip: If the zinc smoke from brass, manganese bronze, et cetera bothers you, the old foundry trick is to drink milk, if nothing else at least it gets the taste out of your mouth.
Jeff Albright
