Maryak 10
Jack,
Just the stitch mop will do me fine, thanks very much.
Best Regards
Hi Guys - (essses),
New week so new piece - The Cylinder.
Took me quite a while to remove the aluminium from all over the shop - don't quite no how but most of it seemed to want to reside in my left boot which was a real pain in the...... foot. ::)
A lump of steel for the cylinder.
Roughing down the OD.
The cylinder after cutting the fins. (That was a load of fun, only broke 2 tools and each time was clean undies
The centre hollowed out ready for parting off and reversing into the 3 jaw.
Bob's blood heat rule saw me stop and go home for a shower ;D
Great documentation as usual Bob. Will be interested in seeing how this cylinder finishes up,
Phil
Thanks Phil for your encouragement, Yep it will be interesting to see the end result.
Steamer - Me SCARED
Best Regards
Looking GREAT Bob!
''(That was a load of fun, only broke 2 tools and each time was clean undies )"
I've snapped off lots of parting tools and blades in my days.
With no mention of a change of socks required as well, I'd say your doing fine! ;)
Rick
Thanks Rick,
It was also a good lesson on why we wear safety glasses
Best Regards
Maryak said:
Thanks Rick,
Best Regards
You got that right!
Bob,
If the bore is not finished yet, put a small 60 chamfer on it and bring the tailstock up. Just enough to get a chamfer all the way around and no more.
The support will help with the grooving.
Thanks Dave,
Good idea :bow:
I actually did the grooving whilst the live centre was engaged and completed it before I began the bore.
Best Regards
thanks again for shareing Bob,I am learning a lot from your posts.
Regards . Ian :bow:
Hi Bob,
Sorry for the mix up there.....its hard to tell how much front rake on that parting tool?
Too much is not a good thing....can result in soiled socks....so to speak......
Seagar,
Thanks for your continued support on my second adventure. :bow:
Dave,
I guess it is hard to see the rake as only the rear of the parting tool is in shot, probably somewhere around what you can see, only the other way up. The tool in the tool holder is a finishing tool for the longitudinal. Thanks for your continued interest.
Best Regards
Much cooler today so spent a bit more time in the sweat box - hit +40C at 2:30 so called it quits.
Here's what went down today.
Setting up the cylinder in the 3 jaw - the parallel is positioned to measure the length more accurately.
The bottom of the cylinder to length and the dia is the PCD of the transfer ports.
A Gerry and the hat tricks poor mans angle plate for drilling the transfer ports. ::)
Drilling the transfer ports.
Drilling the exhaust ports
Milling the exhaust ports.
And that's it from him today
Bob looks real good
I really like your inginuity with the threaded rod to get the angle
i would not use it with a fly cutter, but punching small holes straight down ...
cool!
the whole thing is looking great Bob
i see adelaide is sweating too! keep the fluids up, dont work too hard,
and take care of you and yours , its a tad warm not to eh..
oh and rag wheel on the way
cheers
jack ..
Bernd & Jack,
Glad you liked my angle improvisation - cribbed the idea off my satellite dish where it was used to fine tune to the satellite.
Thanks for your support and encouragement. :bow:
Thanks for the rag wheel jack.
Got a little done today progress interuptus came with a sheet metal job on a wine tanks insulation.
First up I completed the exhaust ports.
Back to the lathe a turned down the locating spigot for the cylinder crankcase interface.
The crankcase mounted on the cylinder spigot.
As an aside when moving chucks etc from one machine to another I find it's easier to get repeatability if things go back where they came from. Just a simple centre pop on the lathe and rotary table backplate matched to a similar centre pop on the chuck or face plate.
The transfer passages on that engine are the two drilled holes parallel to the cylinder bore?
Coool......Most of the time I see that feature as some brazed on assembly.
Looking good Bob!
Started late finished early
The bit in between was mostly boring. ::)
Boring, (the cylinder).
Together at last.
A lump for the drilling jig.
Now for the weeks paper work
Yes they are, there are 4 of them, another 2 on the side you can't see. They are drilled at a an angle to the bore so that if I've done it right they come out in the bore below the top of the exhaust ports.
It's called Oliver porting after the guy who invented it and removes all that nasty offset and transfer cover plate silver soldering from the equation.
Have a look at my offerings in the Plans Board topic "The Maryak 10" http://www.homemodelenginemachinist.com/index.php?topic=3629.0. That should give you a much better idea than my ramblings.
Thanks for your continued support and interest. :bow:
Some of your work holding techniques are great and I hope you don't mind if I borrow a couple for later on in this project.
Best Regards
