Maryak 10
Sean,
First up - Welcome to our forum.
Thank you for your kind words. :bow: This is only my 3rd model so compared to many members here I am a newcomer. I am glad you are getting value from this work in progress, if you get half as much out of it as I do that's really great.
What do you plan on starting with ??? If you are new to machining then the general consensus seems to be start simple with a wobbler. If it's only the model part that's new then I would recommend something in the larger sizes to get your head around working with small parts.
ENJOY
Best Regards
Hi Again,
Today saw a start on the venturi. I did a drawing but didn't like the proportions so this part is draw as you machine as you draw.......
A lump of Aluminium for the venturi.
Turning up/down the venturi body outside.
Machining the inlet throat of the venturi.
Set up for milling the mating flange and the cross piece for the spray bar.
The mating flange and cross piece milled.
After this I had my bone density test and I am pleased to report I'm normal ??? (not too dense and not porous) ::) ::)
Best Regards
congratulations for your good healt!
but I wish add congratulations for this great thread, that is particularly useful for us newbies
when I have completed my second steam engine, I wish try to realize an IC engine, but I don't plan to make plane models on which mount the engine...
it will be only an exercise work :)
Bob,
So glad to hear your well!....hope that chopper is squared too also!
Nice looking carb!.....What is the plan for fuel? ether?.....
Looking good , Bob.
I am very glad that you are able to get back in the shop some. I know I get very unhappy when I can't get in some play time for health reasons.
Gail in NM,USA
ariz, Dave, Gail and Steve,
Thanks guys for your kind words, support and concern. :bow: :bow: :bow: :bow:
Fuel ether this or ether that ;) - seriously ether, kero and castor oil.
Made a little more progress with the venturi today.
Cross drilling for the spray bar.
Reaming the plain section of the spray bar location.
Set up for rounding the cross section.
Rounding the cross section.
Big post Easter sales so we're off to see if there is cheap floating floor planks ;D
Best Regards
Great work Bob and nice to see the set up for everything. Good shot of your reamer. I notice the angle on it doesn't seem as shallow as the others you showed. Do I take it that the deeper you need to ream the more you need to grind off?
Peter.
Peter,
I would say yes to your question if it was a blind hole otherwise it doesn't seem to matter all that much on a through hole.
Thanks for your support and interest. :bow:
Best Regards
Another week slips by - ah well that's life ;D
The venturi is almost finished only the bolt holes to drill.
Machining the taper on the flanged end.
Various views of the venturi.
Where it's supposed to end up on the engine.
And now to rest my weary bones. :eek:
Best Regards
ohhhhhh yessss you have to!!!! :big: :big:
Nice job... :bow:
cheers
Paolo
Thanks Paolo - for your support and encouragement. :bow:
Managed to finish the venturi and fit it to the crankcase.
Drilling the holding down holes for the venturi.
Next came how to hold it in place on the crankcase whilst I drilled the stud holes......... Messed about with various clamps and various ways of holding said venturi all to no avail. Tea and a *** later I ended up holding it in place with my hands and giving the tapping drill a judicious tap with a hammer to locate hole 1.
This was tapped and stud one fitted.
Guess what the bloody nuts wouldn't fit
so the venturi went back in the lathe and the diameter above the flange was reduced to cater for the nuts.
This secured things whilst I drilled the diagonally opposite hole.
Again tapped and studded.
Back to the drill and drill the last 2 holes and the centre hole into the crankcase for the inlet valve.
The completed fit of venturi and crankcase.
Nice shot of my middle age spread ??? ??? ???
Enough brain drain for one day, well for me anyway ::)
Best Regards
middle aged spread :big: :big: the way i like to loke at this is it took me 40+ years togrow the darn thing so im good. :big: ;D :bow:
Thanks Sid,
Good one. :bow: I must remember this for future smart alec comments.
Best Regards
Dave,
Thanks for your compliments - although I'm not sure which you like more. ::)
Tried my model makers glass bead blaster today. What a P.I.T.A. probably more due to operator ineptitude rather than the tool. :eek:
Marking out the crankshaft for X drilling the inlet valve hole.
Drilling the holes for the holding down bolts.
Masking up for the blasting.
The blasted crankcase.
Have a great day, well at least better than me, (suffering from FIM disease).
Best Regards
I AM in shape - round is a shape!
Superb work Bob. Its getting closer........wacth for the kick back on starting it may flip the world over! Austalia could be the new North and the UK could get some sunshine!!!!! :big:
Tel,
Thanks for your input - pleased to note your impeccable taste has not deserted you. ;D :bow:
Mike,
Thanks for your continuing support and kind words. :bow:
Best Regards
Most impressive I must say. Most impressive indeed. :bow:
BC1
