Marine vertical valve gear Programs
Dan Rowe
The thread on Pat's engine made me think of the article I wrote for "Steam in the Garden" about the programs by Charles Dockstader and Rainer Radow. Both the programs are free so the article I wrote is also free.
I am a Shay fan because it is really a marine vertical engine on a locomotive. Getting Dockstader's Stephenson program to work with a vertical engine with out rocker took me a bit of work. The article is the same engine running in both Radow and Docksteader which is a marine vertical engine with direct Stephenson gear and marine links which is all that Radow will do except a nonreversing engine.
The Dockstader file (dso) for outside Stephenson gear is attached. I have to find the program file for the Radow program I have a bunch of versions so I have to check for correct file to go with the article.
Edit here are the program links
http://www.steamboating.de/valve/valve-maine.html
http://www.bittercreekwesternrr.org/Dockstader-Valve-Gear.html
Dan
View attachment Issue 98 update links10sept10.pdf
View attachment D-R-0.dso
