I had a new break-through today.
Making tiny parts in sand is a real pain. So I decided to make the moulds out of core sand, and embed these molds into oil bound sand (for the runners etc.).
That worked to some extent, but the failures still were too many. And it didn't work for very intricate parts.
So I experimented with pressure casting into core sand moulds. But that failed miserably. With hot chamber, the plunger seized, with cold chamber, the metal froze.
So I thought about vacuum assisted casting. But I didn't have a vacuum pump with enough volume and pressure. When I went buying my milk at the farmer over the road, the vane pum in his milking chamber hit my eyes. Next day to the service tech for milking stations in the next village, and home I went with a pump.
Made a vacuum chamber out of MDF and cast a lid. The first tries worked somehow, but the surface was terrible. The molten aluminium diffused into the sand. Some moulds bursted (within the box, so no harm).
So I needed some simple means to adjust the pressure. This is the result:
The vacuum chamber
The lid. The array of M6 screws is for adjusting the pressure by experimenting. In the center, the molten metal is poured in.
Back of the lid and how a mould is fixed.
Results:
This is the batch of tries I made today. Only the pour in the lower right has some shrinkage, but the temperature was too low.
The others came out real nice.
So I have casting #7. A lid for a bearing housing.
Thickness is only 2 mm.
From the rear with the gate sawn off. The "A" is from an experiment with the wash. Just to know witch one went where.
Casting in the mold, one half hammered off.
Seen from the rear, with the "runner" still in place.
Cores and core boxes involved for that casting.
A similar, albeit a bit bigger mould assembled.
Nick
