George Britnell---At the time I was considering buying gear cutters, I posted the question on two or three forums, asking advice as to what would be best, 32 DP or 24 DP. I truly didn't know, and was seeking input from the more knowledgeable machinists . I never did get a clear answer, so concluded that most people on these forums simply didn't know the answer. In retrospect, if I had it to do over again, I might buy 32DP, but the 24DP have worked fine for me. Today was the first I have ever had a problem cutting 24 DP gears with my mill. I used exactly the same set-up, depth of cut, and feed rate as I have used with many previous gears, and I was actually getting SPARKS off the 1144 stress proof as I cut it. This surprised me, because I had no problem cutting the 1144 stress proof in my lathe.
