- Jan 17, 2009
- 1,081
- 281
There is no need to case harden Drill Rod or Silver Steel since it has already ~1% carbon. Heat with what you have and quench in Oil or Water or Brine depending on the grade. (If you are inclined to be that sophisticated, otherwise water works or it may crack a large part.)
If you plan to cut steel, temper to a pale yellow and quench or set in the toaster/oven set to ~ 400 F for about 20 minutes, look out for SWMBO. If you cut only Aluminum tempering is optional.
Case hardening is not really an home shop option, at least in my shop.
