Making a Phase 2 QCTP 100 Series Tool Holder
jamesemery728
Hi All, I need to make another tool holder and I don't have any dove tail cutters. I know that the angle needed is 60 degrees but I am not sure of the diameter and the width that I need to order to make the dovetail for the 100 series. Since I don't own any dovetail cutters and have never ordered any, can someone give me some advice so that I order the correct size. Thank you in advance.
Yup that sounds about right deere.
You can measure the holders that you have using roll dimensions.
If you need a description...shout.
Another way to make the dovetail is tilting the head on the mill in the correct angles (If your mill can tilt the head) and then with a double cutting slit saw milling the dovetail. I've used this way once in a similar project where I couldn't get a hold on a dovetail cutter large enough in the correct angle. This is just a suggestion, using a dovetail cutter is of course the best way. Good luck! somehow you always need another toolholder! hehe
I never would of thought of that!! Narrow minded I am.
Matt
Thanks for all the responses so far.
Tin-Good point, $9 would be less than the cost of the dovetail cutter but.....making one would be a good learning experience.
mhh-great idea but unfortunately my mill does not have a tilting head. Always nice to know that there is another way to skin the cat.
If you are going to the trouble of making one and buying a dovetail cutter make 3 or four then cut apart and finish
Here are some tool holders I made for my mini lathe the factory original A2Z CNC is in the middle.
I did my dovetails on the shaper.
Tin
Hi Tin,
I followed your link to CDCO and couldn't resist. I ordered three tool holders @ $8 bucks each. They arrived yesterday and wow, they are very nicely made!
Your damascening looks great on your tool holders!
