Congratulations Pat, nice engine!
John W
John W
Don't feel bad Pat. Damn few people are aware that there is a difference, and information on make and break engines is quite hard to come by. You're right, Make and Break engines controlled the engine speed through Making and Breaking the ignition circuit of the engine. Hit and Miss engines controlled engine speed through the use of counterweights on a governor operating a linkage to hold the exhaust valve open during the "miss" cycles. I just did a search for "Make and Break" engines, and there isn't much information available-- and some of what is available describes hit and miss engines, not make and break engines. Here is a link to a make and break engine running a small boat, but very little in the way of technical information.---Brian
Try turning the lights down low and attempting to start it - maybe the plug wire is arcing- on a nearby part of the engineHello,
I am a retired auto technician and have worked for 40 years in the auto industry, most recently as a Master Toyota Technician. I know engines and what makes them tick. That being said…..
I recently built a freelance 1 cyl. make and break engine. It is a 1” bore and 1” stroke. I purchased the TIM-6 ignition system. I decided to use this because it eliminated points and condenser and for size reasons, that made sense. I assembled the electronics and tested everything as per the instructions, and all is good. The system was installed onto the engine with the magnet on the cam gear and carefully aligned with the hall sensor which is mounted to a pivoting arm so as to be able to adjust the timing.
To make a long story short…. I can’t make this engine even pop. I’ve tried 3 different fuels, 2 different spark plugs, made 2 different versions of carburetors, and now has a carb off a model airplane engine. I tried priming through the spark plug hole and even tried starting fluid “ether” to no avail.
With the spark plug removed and grounded it shows a good spark. I mounted the LED timing indicator so as to be visible and the timing is perfect. Compression is good and its getting fuel. If I got even a hint of a “trying to fire” or a pop on ignition I would try to isolate a problem. BUT… I can’t get it to show any signs of ignition.
Is there a possibility of a bad coil? I tested the primary side to about 6 ohms and the secondary side is around 5K ohms.
Could it not be firing under compression? There’s no way to test that. The TIM-6 seems ok. I’m stumped.
I thought I’d write the forum to see if you could shed some light…. I need some help.
See the photo of my engine.
Thanks,
Pat Janson
[email protected]
Hit and Miss "In the Atlantic provinces of Canada, primarily Newfoundland, these engines were colloquially known as "Make-and-Break" engines."Thanks Brian....
Pat
Possible you can show some details on the ignition system "you built"......include any circuit diagram "you used" and what power supply "you used>I need some help.
