Ditto Sailplane driver's caution on open circuit CT's - normal practice is to short the output when not in use. One of those rare occasions where it can literally burn out open circuit but is quite happy shorted.
So it needs a burden resistor for the test I was suggesting.
If you have a snap on you can do the neutral/live & neutral/earth checks with that. I have an AC/DC snap on "attachment" that plugs into a meter via banana plugs - it gives 1mV/A - handy for connecting the output to an oscilloscope.
I'd try exchanging the surge protected strip for a non-protected strip - those things often have filter caps, MOV's & GDT's transient surge tubes etc. down to earth.
Might be an idea to open it up / diagnose it.
These things are often rated for the degree of permited transient ie 300V, 400V & 500V for 120V outlets. Lower limits are good for protection but more prone to tripping.
The other thing you could try (if the strip is the problem) is to lift the ground end of the protection devices from earth and put them down to neutral instead - so the transient is more likely to ballance out at the GFI although phase shifts can still **** with it.
This modification obviously destroys the strips ability to protect you from a simultaneous rise in your live and neutral voltages relative to earth.
Perhaps you can re-engineer the strip to a low sensitivity to neutral (300V) and a much higher sensitivity (500-1000V) to earth.
The GFI trips might just be symptomatic of the strip actually doing its job and your problems are caused by a ratty supply - or something on your system (neighborhood / locale) is generating overvolt spikes which are being dragged down to earth by the strip.
Obviously if you have had equipment failures caused by overvolt transients - and that's why you installed a surge protection strip - then its doing its job - leave it in and live with the occasional trip or try and hunt down and kill the source of your tormentor.
Regards, Ken
Regards, Ken
