I have tried my hand at just about every kind of crankshaft construction I know of. Many successes, some that went terribly wrong, and some that I "made do". I have found that the absolute best material for a crankshaft machined from solid, is 1144 stress proof steel. Unfortunately, I am only able to buy it as round stock, so there is a lot of "hogging" to end up with a bar of flat material. It is a marvelous material, because as parts of it are machined away, internal stresses don't try and make the rest of it move or twist. I turn the material between centers, using a lathe dog to make sure it doesn't slip when I am machining it. This is an excellent way to make a crankshaft for a single cylinder engine with only one "crank throw" on it. There are numerous "how to" posts on the internet about machining a crankshaft from solid, so I'm not going to try and repeat it all here.
I find however, that if you try and use this method to make a crankshaft for a double or triple cylinder engine, it is very difficult to keep things all moving "true", and you get into some very scary moments when turning the con rod journals with the tool stuck out a ridiculous amount.
Many of the crankshafts I have made from "built up" pieces press fitted and Loctited together give satisfactory results, but there are pitfalls in this method as well. I traditionally use plain cold rolled steel for my crankshafts and crankshaft webs, and get good results. However, there is a caveat in doing this, and it has to do with "press fits". I have "on size" reamers, and reamers that are 0.0015" undersize. Cold rolled steel generally comes in .0005" undersize, so you don't really get a 0.0015" interference.--You get a 0.001" interference. I have always thought that .001" interference is not enough, so on many pressed together crankshafts I use "drill rod" because it comes in "on size" and you do get a full 0.0015" interference.
--After building the most recent crankshaft in my "back to steam" thread, I am of the opinion that .0015" interference is dramatic overkill, especially if you are building to a design that has thin web plates (3/16" in my case".) I think that .001" interference would have been sufficient. The mere fact that you are pressing so hard to get pieces together sets up stresses in the main crankshaft that will cause it to move far out of alignment. When the pieces of the main crankshaft are cut out between the web plates, these stresses become less, but they don't completely go away.--I ALWAYS use Loctite when assembling a built up, pressed together crankshaft. The Loctite rep says that even though the majority of the Loctite will be pushed away by the press fit, enough remains at a microscopic level to strengthen the joint by at least 30% over not using Loctite at all.
---The problem I see with the crankshaft I just made, is that the web plates are too thin in relationship to the crankshaft diameter. There simply isn't enough material in a 3/16" plate to make a really sound inflexible joint with the mating crankshaft.
---In my opinion, if I was designing an engine from scratch with a built up crankshaft, I would try and make the thickness of the web plates at least to the same thickness as the crankshaft diameter.
---I "cross-pinned" the joints on my crankshaft with 1/16" diameter steel dowels, but with such a thin web plate I don't know if pinning the joints gives a more secure joint, or makes it weaker because you are removing 1/3 of the cross section of the web plate.
--I am giving some thought to tapered reamers and tapered pins at the joints if I do this again, but I really have very little experience with tapered pins and reamers, especially with the small diameter (5/16" to 3/8" diameter) crankshafts I generally use.
----In my early days of crankshaft building, I silver soldered some built up crankshafts together, but the results were questionable. The joints were extremely strong, but the application of heat tended to pull the crankshafts "out of true" which sort of defeated the purpose.
---That is everything I have to share with you about crankshafts.---What do you guys find works best?---Brian
