joco-nz
- Feb 21, 2016
- 568
- 209
... the other thing to engage in is welding warm up just before starting on the real project. You want to get the mind and muscles working in sync before attacking a work piece with dozens of hours in it. This would apply no matter the process, be it silver solder, brazing, oxy welding, stick or flux core. Get your machine and mind dialed in before hitting the real stuff.
This is SOO TRUE! :thumbup:
Something I have finally learned, especially for fiddly processes like Aluminium welding or where you need to be able to keep a point a long way from your hands under mm level control i.e. a good old Stinger.
I get some scrap and run a few beads to get my mojo back in the game, get the muscle memory going again and just to relax. Brazing or welding when you are tense is going to end in a screw up.
When I look back over time at how I was positioned and feeling when I ran a stick bead and had the slag peeling off on its own or got a nice "stack of dimes" TIG weld look I was in a comfortable, well balanced position, breathing evenly with no muscles tensed up through the shoulders and arms. It probably sounds a bit "mind and body is one Grasshopper" but seriously it really does make a difference.
J.
