Norman:
While it may not require a high degree of accuracy Gay suggest several stages of enlarging each and every hole. instead of just just throwing them on the drill press and drilling out the holes.
In Fact all his centre holes he chucks up the work piece in the lathe and drills out each hole using successive drill bits before running a reamer into the hold for final measurement. That seems rather precise to me.
I look at it similarly as the Tormek DBS-22. Find I have to use the magnifier to align grinding of the drill bit other wise the flutes do not end up equal.
Performing Drilling operations with a well ground and accurate drill bit is a very different experience. very little pressure is required and oddly enough the drill remains sharper longer.
see article
DRILL POINT GEOMETRY , an article by JOSEPH MAZOFF
by JOSEPH MAZOFF
Mr. Joseph Mazoff, Inventor, Member of the Society of Manufacturing Engineers and President of J & A Machinery started his metal crafts career in Pennsylvania as a young apprentice of nine years old in a black smith shop in 1926.
In 1938 at age 18, competing against more than 300 experienced competitors in their fifties and sixties, Mr. Mazoff took first place in the Pennsylvania state wide tool grinding contest, including twist drill sharpening.
The entire article is a worth while read. As it turned out this was a war production secret of the Americans, extend the ability to drill holes faster, longer with the same tool be came very significant. I had a friend whose father was a tool and die maker and during the war was sent into many places to sort out the machining processes to enable wartime production. These were dark and desperate times. Depending on the country you live in, some literally ate and slept at their machines for the duration, while this was not the case in North America, we were very spoiled. Some countries, your work was you LIFE.
