I think I will keep my tangenitals well away from the lathe !
Hi Radar,
You might also take a look at the indexible HSS tooling sold by A R Warner of Latrobe, PA. http://www.arwarnerco.com/c-12-turning.aspx
They sell some 1/4 shank turning sets that would fit the Taig lathe you mention.
Chuck
Kuhn, I found a nice set that is 5/16ths. Would I simply need to shave a little bit off the bottom- or would they likely be fine as is?
Hello mr Carlson
Will You be interested in testing my 2mm square carbide plus holder compared to the best HSS you have?
If you tell me distance from top of compund surface to centerline I may have a holder.
If You also tell me Yor adress things go of monday.
Given same degree of tender loving care resharpening(2 minutes) carbide will be even with HSS all the time and more,but it is nice if it can be confirmed from a respected and independent source.
A 3mm round 65mm long ,polished carbide is around 2 and my almost square 2mm will be around 20 .Best german
Oh, I have something I forgot to mention:
-hand tapping machine
Will a three jaw chuck work to hold taps well enough- or should I look into something else?
I'll let someone else answer the band saw question. As to the hand tapping machine, opinions will vary, but I do all my tapping in the mill or in the lathe. I've drilled the hole in either the mill or lathe, so why not tap the hole while you are on location. I've not felt the need for a hand tapping machine, because of where I do my drilling.
Rather than a three jaw chuck, I'd suggest a tap wrench with a sliding pilot. Some are spring loaded, but then you have the spring loading the tap. Ok for larger taps, but not so good for 2-56 etc. There are designs for sensitive home built tap holders/wrenches out there. Again, I'm speaking of tapping in the lathe or mill.
No need to apologize for asking lots of questions. That is how we learn and how new ideas turn up in the forum.
Chuck
Alright this is going to sound stupid- but is I am starting to really notice a pattern here:
Micro-Mark and Harbor Freight clearly are selling some of the same products but one of them, the one from New Jersey, is clearly price jacking the same products.
At least one of the two above is required as eventually you will need to sharpen HSS tooling. Both have their advantagesOh, I have something I forgot to mention:
Aside from the obvious (mill and lathe) for work on smaller models and the like I will be making, I was considering the following:
-1" wide belt sander
-6" grinder
You could use the bench grinder as sort of a stand in for a buffer. If you like shinny models though I guess a buffer is required. I'd probably go with a tumbler first.-buffer
Not required by any means but a huge convenience.-band saw
Such presses cam be very useful but if I was to buy an arbor press I'd most likely go larger.-1/2 ton arbor press
This is something you can make. Frankly this and even some of the machines above are good DIY candidates. Practice on none models leads to broader skills development.-hand tapping machine
Well if you catch the tool bug the answer is no. On the other hand some of the tools above, such as the bandsaw, take up a lot of space.Now, what kind has me scratching my head a bit with this whole matter is this: for small live steam engines and other small projects in general, is some of this over kill?
I'm not sure what you mean by rewriring. There is a massive difference in SFM (Surface Feet per Minute) between a wood working machine and a metal cutting one. This means that you need a form of gear reduction to retask a wood working machine. This is another DIY project.If I were to get my hands on a vertical band saw could I get away with rewiring a wood cutting band saw to work for metal?
Small taps maybe. Here are a lot of crap chucks out there. At some point thought drill chucks won't supply he torque required. This usually isn't a problem in a model engineering shop though.Will a three jaw chuck work to hold taps well enough- or should I look into something else?
In some cases yes. In other cases I suspect HF sells the seconds and screw ups.The big one that really has me wondering though is this:
Is it just me or does it seem like Micro-Mark sells a lot of stuff that I could buy from Harbor Freight (to the point of it being exactly identical) for much less?
I apologize about bombarding this place with questions.
Thank you sir- what about the rest I had mentioned? Anything seem like over kill to you?
Arguably, the best tapping tool is the one by George Thomas in his Workshop Techniques book.
This is not only a tapping tool but capable for staking/riveting and drilling with the ability to do divisions etc, Whilst the tool is available as castings from(say) Hemingwaykits it can be fabricated by welding. My first came from an old boy, long dead now. To make the fabricated one does involve either silver soldering or brazing or welding but once you have one- need I say more?
It's a class act and you can get into interesting things like making your own division plates.
Norman
I think that I could make a simple hand tapper with out any issue- and for a lot less.
Or you could use your pillar drill or mill and a short bar with a point at one end and a countersink in the other for locating the work then keeping alignment and applying pressure on the back end of either countersunk or pointy ended taps,
- Nick
