Well, I got a few more parts done in the last couple days.
First is the two valve rods.
Next up was the four bushings for the valve rods.
I just got about $600 worth of indexable tooling and holders. This is the first time I got to make something with them.
This was in particular makes a very fine surface.
Here I am pressing the bushings into their respective holes with my homemade wooden shop press.
Here is a shot of the installed bushings.
Next up Its time to make the crankshaft.
I started by making 4 disks out of brass with a 1/4 hole drilled in the center.
After drilling the throw holes, (sorry no pics) I mounted all four in the vice with rods through both holes to line them up.
I first cut most the material out with a regular and mill.
Then I used a 1/2" ball end mill to make a radius.
Here are the finished crank webs hangin' out with the gang.
Next up I had to make some spacers for the bearing on the crank throw.
Here is a pic of me parting them off. (they are .035" thick)
Here is a shot of the crank web and bearing assembly before pressing together.
and the finished crankshaft. (sorry no pics of the pressing process)
Thats it for now.
Kel
