Charcoal can be used instead of CO2. I used that a lot over years when had oven.
Now I just torch for few small parts.
The only way to prevent the black iron oxide from forming is to prevent oxygen from contacting the steel. This can be done by
Apart from the wrapping in foil and the painting on of a protective coating processes, all of the other processes mentioned above will still result in some de-carbonation/forming of iron oxide when the part is removed from the heating container prior to quenching, and it then makes contact with oxygen in the air - but this process should only take a second or two before the part is quenched into water or oil, and the de-carbonation is usually not very severe.
- painting on of certain "mixes" such as those mentioned above (results are very variable)
- wrapping the steel airtight in stainless steel foil (my preferred method that works with 99% reliability)
- removing the oxygen from the kiln or oven where the steel is heated - this can be as simple as dropping a piece of wood into the kiln/oven a second or three before the part is placed inside this kiln/oven. The wood will then ignite, and burn up most of the oxygen in this oven (obviously the oven should be rather well sealing to prevent fresh air from moving in and replacing the O2...)
- if using a forge, one can place the part just inside the top layer of coal/coke/charcoal that is used to make the fire (in the region where the flames have used up most of the O2) - this sounds crude, but is how most tools were hardened in the years before electricity...
- using a reducing flame on a cutting torch and holding the part " just right" where the oxygen in the flame had been depleted, but not so far away that it is exposed to air - very difficult to get right...
- or by placing some inert gas (CO2 works well) inside a metal tube that is closed off air tight on it's bottom, and then heating this tube in a furnace/kiln/forge with the part hanging some way down inside this pipe. The heavier than air CO2 will stay inside the pipe even when heated, and this process works well if one uses a pipe that is (say) 200mm taller than the top of the part hanging in it, as this slows down the process of air diffusing down into the pipe, but one does have a practical time limit of only about 10 - 15 minutes to heat the part.
Colin, if you don't want to use the foil method, I suggest you follow Tornitore45's advice and just block up the screw holes to prevent O2 from entering the holes. Also, keep in mind that any sharp corned (and threads...) could lead to cracking of the part when quenched, so use a slow oil for quenching, and don't be tempted to quench in water.
Good luck.
Hennie
