Kasey's split single engine ready for testing (again)
Kasey
Brisbane,Australia
After additions to the inside of the crankcase to improve its compression ratio, and getting the head machined with cooling fins, my 170 cc split single/ (twin) is now ready for mounting on the test bed mower base for a higher rev test. The G4 carbie has also been re-jetted to handle the higher oil content of the fuel as well. Attached are a couple of photo of different parts. On its first rev test, it had trouble handling wider throttle openings due to a lean mixture. Later on, cylinder fins will be water jet cut and then be fitted/shrunk on and spot welded in place.That seems to be the only way this can be done as casting fins on the twin cylinders has proved an impossible task.
