Great !! waiting to see it running.
I really wish the company that makes this would ship to the US. I'd buy a kit in a heartbeat.
I was stationed in Mannheim, Germany and I've seen the one in the museum there. I wish I could even get the plans for it. I can understand enough German (I think) to make one. I contacted the company and they won't sell just the plans. -Sigh.
Hi,hello
I made the carburetor as on the plan no problem.
compression is sufficient
I start by launching the steering wheel by hand, plug the carburetor with a finger for 1a 2 turns to suck up the petrol.
My first attempt in starting the engine was not very successful, mainly I think due to the incapability of the ignition units used.Hi,
Thank you very much for your prompt and encouraging reply.
I think that it will be possible to try out starting the engine soon.
In the mean time I will take some pictures and start posting as soon as possible.
Edward.
Edward. If you want something nearer to scale I made a more realistic spark plug.View attachment 115536
The ceramic plug I got from ignition electrode connection M4 L1 35mm 10343 | horecatiger I just ground down the bottom part of the ceramic to 5mm Dia. with a diamond wheel on the dremel. The 4mm thread is screwed onto a 2.5mm thread. The electrode sits well down into the combustion chamber. Just not sure what to use to seal everything when it's bolted in place.
I will be using a surface carb similar to the benz but with my own internal design. A quick general question I have made a float. It is soldered both ends. Obviously the flux can't be removed from the inside. Does anyone see any problems with that or is there a better way to make a float. View attachment 115539
The ignition units were meant to be used in my model rc aircraft. The firing was intermittent to nothing at all.
I believe a strong thick spark is essential in this particular engine, that is why I could see a large HT coil illustrated in the TS site.
Please advice.
Hi gg89220,
Good news. I got the engine running. The main problem was in my ignition unit. It was replaced with an automotive ignition coil and the engine ran nicely.
Made a few short runs with butane Gas, and with petrol using a Jan Ridders universal vapour carbeurator. The carb mentioned in plans was not very successful
in today's runs. May be I will try later.
Pictures and a video clip will be posted in the near future.
Thanks very much for your support.
Edward.
