https://modelengineeringwebsite.com/Jowitt_build_3.htmlI plan to build this one, but I prefers to make my own drawing and make some adjustments, re-drawing the models I can understand one thing.
My problem:
On the inlet side, the valve does not make sense to me...
From what I see the valve seat only "opens" a passage to the fitting between the ø4 rod and the tightly fitted hole it slides in, not really changes flow directions for the pressure.
The exhaust side I get, the valve opens and let the pressure relieve and go out the exhaust hole, closed it seals off the exhaust.
Can anyone explain how the inlet valve is supposed to function?
I'm starting to get frustrated here
Best.
Elias
My problem:
Best.
Elias
