You could probably substitute brass or some other plastic. You make the caps. Probably could get Teflon rod from a plastic supplier or maybe McMaster-Carr.OK, What type of supplier sells Teflon caps?
Doug
Just turn up some plugs they don't need to be pressed on. They are there to keep wrist pin in place and keep wrist pin from making contact with cylinder wall. Usingwrist pin plugs is so you don't need any other means of keeping them in place. Just put a small plug on both sides and no need to drill hole through wrist pin.
Brian, and any other knowledgeable folks, I was gifted a brand new 6 volt automotive coil, but I’m going to run my newest Engine (a Webster) on 12 volts. Does anyone have an opinion on running 12v through a new 6v coil? I’d rather not see the magic smoke appear!Use any points that you can get. Also get a 12 volt condenser to go with the points.
thanks in advance,
Put together a voltage divider. you only need 1k,1.5k and a 4k resistor to divide the voltage to 6.25v
You would need to measure the current when running on 6v and then calculate the value and power requirement of a series resistor.Put together a voltage divider. you only need 1k,1.5k and a 4k resistor to divide the voltage to 6.25v
