Based on experience, I do not recommend silver soldering or brazing the crankshaft. Too much heat distortion. On a built up steel crankshaft, I put a bit of mig weld on both ends of the crank throws to hold them together, then drill and ream them both at the same time so you absolutely know that the holes are aligned. use an "on size" reamer. Cold rolled steel shafting is actually about 0.0005" undersize (drill rod is not). I do not recommend using drill rod. Cut two pieces of cold rolled crankshaft material. One piece is cut to the total length of the crankshaft, and one is cut to the overall dimension outside to outside of the crankthrows. Assemble with loctite #638. Let it set for 24 hours. Then cross-drill and ream .094" in four places and use 3/32" steel cold rolled steel for cross pins. Let set for 24 hours. Next step is very very important---Cut out the bit of shaft between the crank throws. You can hacksaw, band-saw or mill it away. BE SURE TO CUT THE CORRECT SHAFT.
