Hi All !
I am working with fuel pump, ball valve
I have a question : Is diesel oil compressible ?
Thanks !
Thanks !
For all practical intents and purposes, fuel oil is not compressible, just like virtually all liquids (by definition). When you draw a vacuum on diesel fuel trapped in a cylinder, it will instantly boil, forming an oil vapor bubble. The result may seem like "expandibility" (sp?), but it is not.
Hi Ccolby , Pete !Minh-thanh, the short answer is yes.
The liquid had the same stress strain behaviour as you reduce pressure, so if you are able to pull a vacuum, you have reduced stress on the liquid by 1 atmosphere, or about 0.1 mPa and the liquid will exhibit strain accordingly.
As above, the magnitude of this strain will be so small as to be negligible for practical purposes, but evaporation and cavitation are very real problems for a fast acting pump.
This is the why you may need to pressurise the supply to an injector pump.
Pete.
it seems in both cases your plunger goes past the inlet hole, which is bad, on the return stroke the oil will boil (bubble) until the inlet is uncovered but the bubbles may not completely collapse right away, and these bubbles will make it seem like the oil is compressible when (at the scale of measurements we're dealing with) it is not.
this is just an opinion not a tested fact, I'm also building a diesel (Finn Hanson type) and collaborating with Pirmin Johannes, but haven't gotten to the pump and injector, just working on the large parts first and waiting to see what the rest of you diesel builders come up with !!!
Lloyd, (edit by Lloyd) ...........which makes me wonder, how many of your "almost there designs" were unworkable designs or just unlucky machining............ but don't consider the design the problem, just the machining for the one particular valve or seat). Peter.
Pete.
Lloyd, I can definitely relate to the problem of deciding the pitch of threads and how long those threads should be and how much material needs to be behind the threads !!! another note, I've given up on mechanical seals and instead use loctite 542 thread sealant (its medium strength and I've never had a problem disassembling it, if I ever do then I'll try their 577 which is even lower strength sealant). Anyway, if/when I get my Hansen Diesel to work I'll be sharing the design (ditto Pirmin Johannes with whom I'm somewhat collaborating), I hope you're like minded, as Hansen himself (may be a bit of a recluse and) doesn't want to share much. Peter.Peter, yes, I agree with you whole-heartedly, but won't be so polite on myself. A lot of it is just poor execution on my part. Trying to squeeze both the pump and nozzle into one package exposes unexpected weaknesses, and usually, it just leaks somewhere. So, a minor design change to add a little more thread depth here, or little more spacing there, or a little more precision somewhere. I feel like the basic design is sound, but I am now getting ready to re-make the main body with a few minor tweaks to solve a couple of "issues." But honestly, each failure teaches me something new, even though sometimes it is just,"I was afraid that was going to happen."
Lloyd
No, it is a matter of what is called a state property. When the pressure is reduced with a piston withdrawing from the cylinder the volume increases and pressure is reduced forming gases. I say gases because diesel fuel is a composite of several hydrocarbons. The trick is to keep constant pressure on the injection system usually with a primary pump. These gases can vapor lock systems. So you either design the system to inject the fuel into the cylinder so that the delivery injector is empty when it withdraws or you add a booster pump ahead of the injector system. One of the reasons you try never to run a diesel without fuel because it will draw in air and then it has to be bled and primed. A slightly different problem with same effect. If heat is involved the viscosity of the oil is reduced which makes it more sensitive to flashing. There was a modeler on youtube from Norway or Germany in which he described the work on diesels and his injectors. He would talk about his injectors but not release the design for some reason. I will see if I can find the video but it has been some time since I viewed it.Now I don't care about compression nor thermal expansion
Thank you very much !
One more question:
I don't know how to describe it - Like pouring oil into a cylinder and using a piston to create negative pressure, does the volume of oil increase?
