Inspired build of the Benz 1886 Engine
The bore ended up a little over 1" and I will be using an O-Ring on the piston.
These are the parts to the connecting rod and the piston.
This shows it all put together and the rod cut to the correct length.
I am happy to say there were no rod interference problems.
Thanks for looking
Ray
Well I am back from a short vacation and ready to go to work.
I cut out the cam towers and turned the cam shaft.
I also straightened the exhaust pipe.
Since I don't have the bevel gears yet (slow boat) I am not sure exactly of their dimensions so I will make the towers taller than needed.
I hope to remove 1" off the towers height and 0.750 off the crank shaft end when they do show up. I made the towers now to give me a reference point for the exhaust valve linkage.
The cam shaft is over length also.
Thanks for looking
Ray
I made up the rocker arm and outboard lever for the exhaust valve.
I didn't have any brass rod for the exhaust pull rod so I made it out of steel instead.
The clevises for the rod ends are brass though.
I really need to have the bevel gears in my hand before I can go any further on the exhaust.
Looks like a late Wednesday arrival time.
Thanks for looking
Ray
Thought you would like to see a complete and working 1886 Benz. Iqbal made the entire vehicle with just a Sherline mill. It is large enough that his granddaughter could sit in it when she was 1 year old.
Hi,
This gentleman lives near to my place. I always wanted to meet him and learn from him. But I never was able to get his address or contact details.
Nikhil
While I am waiting for the bevel gears to arrive I thought it was time for some color.
Now painting in Florida can at times be challenging with the high humidity and high temperature things don't always turn out as planed. I painted the first few pieces and was rewarded with a pale pink color. Not that I don't like pink but I was looking for a bright red instead.
I got out the toaster oven and set it at 150 degrees. I found that if I could get the freshly painted item into the oven in under 2 minutes and leave it in for 10 minutes it turned out alright.
Some parts were not as nice as I had hoped but most were fine.
What do you think?
Thanks for looking
Ray
I had a day off yesterday as a good friend of mine (Chris) and I went to ACME Surplus in Sanford Fl. They have metal of all kinds and as I needed some brass and some aluminum we made a morning of it. You never know just what they will have but I found some 1/4" brass rod that I needed and some 1/4" X 2" brass plate that was over 6 feet long for $4.95 a pound. That should hold me for a while.
Today I made the housings for the inlet and outlet cooling water connections. I was afraid that the wall thickness of the outer cylinder was too thin for making threads so I made the housings.
The bevel gears did come in so maybe tomorrow I can work on them.
Thanks for looking
Ray
