Diesel Injector Dilemma
After much effort and many "almost works," prototypes of a unit injector, I am about ready to admit defeat and compromise on the issue by marrying an off the shelf injector nozzle with an off the shelf injector pump. The parts will need to be modified to remove excess size and weight.
I think I will be going with the GM (Detroit Diesel) HV6 injector nozzle, and the Yanmar injector pump from their line of LA single cylinder engines (199 to 406cc).
The HV6 nozzle has much smaller holes and the internal spring can be changed to achieve different injection pressures.
Here is a pic of the 2 nozzles (GM HV6 and Yanmar LA series.) I listed some comparison specs from both stylesof injector nozzles.
What baffles me is that the Yanmar is for a much smaller cylinder volume, and operates at over 2,000psi, but has fairly large nozzle holes.
The GM operates at below 1,000 psi, has has a much larger cylinder volume, but its nozzle holes are much smaller. So much to learn, LOL.
Here is a pic of the HV6 nozzle and the Yanmar injector married together. I hope they are compatible. The design of the nozzle and the pump are fairly straight-forward (famous last words, Ha)
There is still a LOT of excess weight and material on the Yanmar pump, but I will eventually get around to putting it on a diet to make it suitable for the model I plan on making.
Testing is next. At first glance, it seems to offer resistance against the plunger from the pressure build-up, just like it should.
This is just a proof of concept prototype, unless it works, that is.
Lloyd
x
Lloyd
x
