- Sep 2, 2011
- 1,381
- 370
I think I have found the next engine I want to build. the Upshur Vertical Single.
I was able to contact Andy and get the drawings. he was very nice and emailed me the plans. - Andy I appreciate that if you are reading. the drawings are good and instruction portion seem to be straight forward as well.
my first question I have is the cylinder is steel liner with aluminum fins and the base flange of the liner has to be soldered on after being pressed into the aluminum fins. so my question is this, instead of a steel liner with aluminum fins, why not make the entire cylinder from steel or CI which would eliminate the need of soldering on the base after the fins being pressed on? this would also allow a little bit deeper fin cuts as well with the exception of the top fin which has to allow for head screws.
any thoughts on this? any tips, info etc from others who may have built this one?
I like the closed crank case that is made from multiple pieces of plate instead of hogged from one large chunk of metal.
edited because I called Andy "Dave" sorry Andy
