I need help identifying the model of my southbend 9" lathe. There is no model number to be found, but a serial number cast into the bed is 52636S.
crazydoug
PA.
It has a v belt head which seems uncommon, the bed is 42" making it @ 24" between chuck and tailstock.
I was going to part it out,but after cleaning years of crud off it, it seems in too good shape for that. I might try to sell it nefore parting it out, but would help to know the model.
This is the number cast into the bed. Serial number or casting date?
    1.9 MB
9A Quick change gear box and feed clutch on apron.
9B Change gears and feed clutch on apron
9C Change gears and no feed clutch
So which model do you have? The 9A is the most desirable and the 9C is the least.
My first lathe was a second-hand SB 9" model B bench lathe. I'm now running a Myford Super 7 but regret not keeping the SB.
Imho, desireability is basically meaningless since each model was intended for a range of purposes. Btw. the Vee belt drive was standard on the 9" Precision and Light Ten Precision Bench Lathes.
Hi, I have 2 SB lathes. The serial #'s are stamped into the bed at the far right by the v-way of the carriage The number you took a pic of is a casting #. Grizzley tools owns the data base of SB #'s and will send you a copy of the file card of the machine for $25.
