I play and collect saxophones, and last week took two over to my woodwind repairer of many years. Whilst there I mentioned the machines and he said he was looking for a milling machine. We identified the Westbury as such.
My plan is to take the Westbury and any suitable "bits" over to him Friday. He can set it up and see if it works, although I noticed the orange drive belt is snapped as here. Or should there be some kind of connector? Otherwise where's best to get a replacement belt the correct size?...
I'll take the most likely attachments and cutters to him to choose from.
At present I'm thinking of taking the MT2 and MT3 autolock chucks, so he has both imperial and metric collets to fit the MT2 version (the MT3 taper being redundant).
I could also take the ER25 collet holder (need to locate its wrench), and the box of collets found under the lathe which are labelled to go with it. They're labelled "Size 2 - 18" but I've no idea what the numbers relate to - would it be mm?
This Myford "set", below, seems to comprise everything needed, taper, collets, extractor sleeve...
Is this a good option for the Westbury?...
I'm still not sure what
@Mike Ginn meant by
"The better solution is to use the collets with a Number 2 Morse Taper shown on the left - note that they are used with the closing nose shown to the right and below a black tube device which is to remove the collet from the nose. These collets sell for about £20 each if you can get them."
Not sure if these are shown in my photos or those Mike posted, perhaps he could clarify?
Anyhow... that's the plan so far. Anything else I could look for to take with me? It's bound to be here somewhere!
Anything not wanted I'll take over to the auction house (it's near me) to re-join the other machines, lathe, etc ready for the auction day.
