And for a change, a few external fittings.
The cylinder oiler was made to the words and music from Morrison & Marvin's 1/4 scale oiler, but sized slightly differently and shaped for this engine. The glass tube was a convenient size cut from a piece of test tube. The elbow started out as one of a street ell casting tree from PM Research. The smallest size was still too large, so plenty of filing was needed to get it to an acceptable size.
The machining jig has been described on this forum before. The design will hold any of the PMR cast fittings of one size.
Inspiration for the priming cup and crankcase drain was drawn from a Stuart cylinder draincock.
I used the same form tool used on the pump check valves to form the spherical parts. A piece of brass hex was chucked and roughed out. Then the form tool came into play to shape the body.
A hexagon was filed at the top of the stem.
[FONT="]
[/FONT]
The cross hole for the handle was drilled and taper reamed for the handle. I did as much work with the part still attached to the parent stock for ease of holding.
The body was then parted from the stock and the threaded stem was held in a mandrel so the cup could be formed.
I could not bend the cock handle either cold or hot. At just over 1/16 diameter, the barrel kept breaking off. In the end, I turned the barrel and made a larger boss and silver soldered a handle to it and then filed it down to a reasonable representation of the full size.
Next was drilling the cross hole for the retaining split pin. The simple jig is just a piece of square steel stood vertically in the vice and a hole drilled for the bore of the barrel. It was then turned horizontal and the cross hole drilled through. This ensures the two holes are on the same line. Slide the barrel into the long hole and there you have your cross hole. Just the taper where the barrel goes through the body to machine now.
And this is how they ended up, the cylinder oiler crept into the picture, also.
The Emerald Isle
