- Mar 17, 2009
- 35
- 8
I have a 7.00 dia. that needs 222 teeth 32 d/p I"m lost I would like to learn how to do the calculations What hole plate and turns and holes Best Regards Red redcraftm
It simple to calculateHello I have B/O 40:1 index tool with all plates
The math is as follows (on edit: the forum software is messing up the formatting ...):
worm ratio
desired # of teeth
holes to move
holes in index circle
Let me re-write that as follows to make it easier to refer to:
W / N = H / C, where W = worm ratio, N = desired # of teeth, H = holes to move, and C = index circle used.
The key to being able to index without using compound gearing is that you can choose C such that (factors of C) * (factors of W) = N. To say this another way, you need to have all of the factors to get to N available to you either in the worm ratio (W) or in the index circle.
Let's factor 222: 222 = 2 * 3 * 37.
Thus, we need to have these factors available in either W or C. If we have an index circle with 37 holes, that takes care of that factor. A worm ratio of 40 has the factor of 2 that we need ... but not the factor of 3. By contrast, worm ratios of either 60 or 90 have both the 2 and the 3 available. The only way to achieve the indexing with a worm ratio of 40 is to put the factor of 3 into C - in other words, to have C = 37 * 3 = 111.
Thus, you could achieve this indexing using a 37-hole circle only if your worm ratio is either 60 or 90, OR if you have a 111-hole circle. (I am assuming the common worm ratios of 40, 60, or 90, and no compound indexing.)
