- Feb 8, 2013
- 274
- 187
Hallo Werowance,
Thank you for your compliments about my B.J.CICADA model diesel engine.
I must say that i do n't have much experience in making model engines.It was one of the 4 engines i made till now.The first engine a Boll Aero 1,8 cc was made during the Winter of 2007.I just started a new project making a model glow engine with a cilinder capacity of 8 cc.It's a one Cilinder long stroke engine again and is a hughe engine.We'll see were this ends.
The material for your Cicada Crankshaft can be LN 24 Steel or EN24 or EN36
or anything in reasonable steel will do.I used a normal kind of mild steel
to make the Cilinder from and it worked great so it's better to choose a kind of steel which is n't to hard because of the reaming/lapping and honing work that later needs to be done.
A good advice be sure that your transfer grove which comes half into the Cilinder stops half way the exhaust port so do n't let the transfer grove go deeper than the exhaust port.The engine will not work or can n't start and run either.
I hope that you can use my advice and if you do need more answers on questions please feel free.
greetings from modelmotor.
