Hi
I'm trying to make some small studs, the photo shows a first attempt and the crude drawing (not to scale) gives the size. To Hold the 3/32 stainless steel rod in the lathe I took the 3 jaw chuck off and fitted a drill chuck on 2 morse taper in the mandril. Threading the first end using a tail stock mounted die holder is no problem but after parting off its extremely difficult to hold the little blighter to thread the other end without damaging the thread or the shank. I've tried screwing the threaded end into a piece of drilled and tapped steel held in the 3 jaw and then threading the other end but then I have difficulty getting it out of the steel without damaging the stud, in fact the last one snapped off! I'd be grateful for any ideas how to hold them.
