Hi I am building the Hoglet V twin and about to start on the con rods. On the drawings it shows no bearings in the small end. I intend to fit a bronze bush here as its running on a steel gudgeon pin. The big end forked rod is a press fit on the bearing thats fine. The other which runs on the bearing I intended to fit a steel liner to run on the bearing. This seems good practice to me, what have other builders done.
