Bowlweevil
- Jun 18, 2017
- 12
- 7
I have completed my Hoglet engine along with the howell 2 jet carburetor. I'm running Coleman fuel with wd 40 added at the rate of 6 oz. per gallon. I've read several (all different) methods of setting up the Howell carb. I made the needles as per the drawing so they are stubbier than other needles I've made in the past, therefore only a small adjustment makes a big difference. 1/4 turn on either needle floods the engine. I can get the engine to idle and it sounds great but cannot get the throttle to respond--UNLESS I cover the vent hole on the gas tank cap. Then the high speed comes in but it quickly dies. The hole in the cap is 3/32 (.09375"). What would be the reason it would rev up when the hole is covered? I've read where Brian drills a .040 hold in the cap, so maybe the size creates a draft effect. I've build the Kerzel and the Webster. The Kerzel has a hole in the cap and the Webster doesn't. Thanks for any help.
Mark
Mark
