Hoglet started (and running!)
I opted to drill the holes before cutting the fins. There was a small amount of wander in a couple of the holes, I mostly solved this buy enlarging the holes by 0.5mm in all but the top fin so the heads would still be corectly located. One of the holes also needed a lick with a file just to pull it over a bit more.
If I were doing it again I would start with a stub drill after the Ctr drill or cut the fins first and drill all the way with a 1/8" centre drill changing part way for a long series one, then open up to 4mm (I used M4 threads on 5/32 rod)
Jason
Thanks Phil, Chuck and Jason.
I've got some hollow cast bronze for my flywheels so just need to skim them inside & out
I was looking for that, I had some but wrong size, Shame to waste all that brass in the centre.
how difficult was it to drill the long, deep holes
I haven't drilled them yet. Thought about drilling before the fins like Jason suggested but I was in a turning mood.
So now I might centre drill and drill each fin. Also my parting tool deflected a bit leaving the fins slightly tapered, which complicate the drilling further. :p
Stock centre drilled;
Drilling;
boring; (I bored .090 oversize to allow for a .045 wall cast iron sleeve)
Dialing the QCTP back in after setting the compound over 5 deg;
fins ready to cut;
fins cut;
Tapered;
Polished ready for parting;
polishing a few tenths off the spigot end;
And now its starting to look like something! I should change the title to "hoglet half way"!
The drawing for this engine calls for a carb purchased from OS engines.
Does anyone have a suitable design they could share?
It would be a shame to slap on a factory made component.
Thank you very much.
I have a suitable OS card laying around so will us ethat to start with. May decide to build one which was in Model Engineer Mag a few months back, there is a picture of it fiotted to one of the designers engines half way down this page
Also worth a look at his latest design the "Bobcat" there is a video of the first run on the home page.
Jason
Thanks Jason,
That carb would be perfect! I also have an OS carb I thought about using just to get up and running but I have come this far...
I think between that nice photo and Maryak's step by steps, I should be able to come up with something.
What are you doing for your ignition? Electronic like the RcExcel?
It is very compact and I think it will run off a single Lipo cell.
Kevin.
kustomkb,
Very nice, :bow:
Glad my ramblings are of use to others.
Best Regards
Thanks Bob,
It's a real help, none of us were born with these skills so it's good to share. Methinks.
Started on a drill jig I think will keep my centre drill/ drill straight and stiff.
The plan is to c'drill and drill each fin 1/8 in my drill press before opening to a 5/32 slide fit. (wishful thinking)
bore out a large dia. bottom plate to hope for squarness;
Fit bottom spigot;
And tap 1/2-13;
then machine top end that will hold drill bushing;
And ensure fit;
Drill jig without reamed holes for bushing;
have fun!
Drilled the cylinders yesterday.
I clamped the jig to the drill press table, then aligned the bushing with a dowel pin then switched to a long centre drill.
I choked up on the drill for the first few fins and then went to full length. The fins were thin enough so that I was able to pilot drill with the centre drill the whole way;
Then switched to a .146 drill;
And finally reaming size for size to 5/32";
The holes came out very straight thanks to the long drill bushing. And were a snug sliding fit on the studs.
I often end up fighting myself because I make things unnecesarilly close fitting. After trying them out to check for alignment I will need to open them up to ensure the faces of the heads and cylinders are pulled square to one another for a good seal.
Looks good, Kevin. Nice technique. By the way, where did you get that long center drill?
Chuck
Thanks Chuck.
The centre drill has been in my box for years. I also have a 6 inch. Most tooling shops should have them.
Looks like I spoke too soon. One of the holes wandered and will need to be pulled over slightly at the bottom.
It was probably the first hole which I switched to a 1/8 drill after centre drilling only the first fin. :-\
I made the brass valve guides today.
Started by setting a "form" tool to 14 deg. to plunge cut the taper where the intake and exhaust blows by;
and the plunge cut;
Then turned the OD for a 0.0015" press fit;
After drilling and plunging out the back end for 0.010" spring ID clearance it was ready for parting off;
Final reaming will be done after instalation.
Next up, finish the heads.
hey can i get some of that talent so i can make prety parts like these. i really could use some.
thats coming along real nice. thank you im in school everyday.
Thanks alot Sid.
"If you build it, they will come"
A little more today.
Drilled the intake and exhaust holes;
Then drilled and reamed for 1/4 dowels to set the fixture over 21deg.
I reamed a scrap of AL. to ensure the pins pressed in square;
Then replaced the soft jaw and clamped the fixture in place, ready to mill the angled ports;
Ciao for now!
Kevin,
Nice work. :bow: :bow: ETF ???
Best Regards
Thanks again Bob.
Heads set to 21 deg. for intake;
Intake bored;
Set over for spark plug bore;
Bore complete;
ready for outside contour;
Roughed;
finished;
cooling fins cut;
Test fit of heads;
Also radiussed the tips of the push rods;
And used a crappy tire die nut ::) to threads 4-40
which cut okay :eek:
Then faced to length and centre drilled the push rods;
And turned down between centres, (had no 3/16 AL)
Have a good day!
Hi Kevin,
Wow that's look'n real good...keep up the great :bow: work :bow:
Can't weit to hear it run and that's no th_bs
Have a great long week end.
Philly
Kevin,
Beautiful job. :bow: :bow:
Best Regards
Thanks alot fella's.
This weekend I hope to get the valves and lifters finished and rough out the cam.
Looks like we'll have nice weather for the long weekend finally, eh Phil?
KB
Yea nice for the long weekend and a :-* HONEY :-* DO LIST a yard long. :shrug: Maybe I'll have to go on an building materials run and pop by.
Philly
