Hoglet started (and running!)
Jason when doing your spark plug hole once on angle how did you know where to machine your hole i.e. I know it's .813 but that's when it's horizontal, I could layout with a mark and use a wiggler once on 30* to machine the hole but isn't there a different way to accurately find the dim once the part is on the angle specified? I know the cam housing you put on center and rotated the rotary table the degrees specified and that was your dim. Is this the same? Could you some how mount this on a rotary table and rotate 30*?
Thanks again Bob.
Heads set to 21 deg. for intake;
Intake bored;
Set over for spark plug bore;
Bore complete;
ready for outside contour;
Roughed;
finished;
cooling fins cut;
Test fit of heads;
Also radiussed the tips of the push rods;
And used a crappy tire die nut ::) to threads 4-40
which cut okay :eek:
Then faced to length and centre drilled the push rods;
And turned down between centres, (had no 3/16 AL)
Have a good day!
Scribe a line 0.813 from the ctr of the head.
Set work in the vice at 30deg and line up on ctr line
Use a pointed wobbler or "sticky pin" to pick up the position of the scribed line, with a good eye you should get to within a thou or two.
If you are not sure then shout and I'll mock up a photo.
Hi, Nice work ,please keep the photos coming.
Allen.
I was asking a question to Jason and quoted his post but didn't realize it'd repost all his pictures, he's done with the build. If you look thru this thread you'll see his progress.. all the way thru to the end. He has some awesome.. scratch that.. AMAZING talent!
