@Peter, that slide hammer/hand-wheel looks brilliant, though it does raise a couple of questions/concerns when you run the mill. It sounds as though there is quite a bit of vibration, which I think would be the shaft spinning inside the slide hammer.
(1) Is there really any vibration?
and if so;
(2) does this transfer down through the spindle, to the work piece being detrimental to fine finishes?
(3) hard on the bearings?
What are your thoughts and findings?
At the end of the day, as long as the shaft and hand wheel are balanced enough, the slide hammer can just be removed and replaced when needed. Doing this would also save any future wear between the slide hammer and shaft.
I may just try this on my HM50.
@Gus, They are some nice tools you have made Gus and looking at how you have fixed your chuck, has given me an idea on how to fix mine, thanks so much. Shame Al is in WA, those counter sinks in the blue box would be handy.
Ed
