Maryak
- Sep 12, 2008
- 4,990
- 77
Diymania said:I can barely wait to see this baby run! :bow:
That makes 2 of us. :big:
Best Regards
arnoldb said:I'm curious about mounting the bearing blocks on the mandrel - do you slightly loosen the cap screws, then push the block up the mandrel to where it gets "tight" and then tighten the cap screws to lock it in place ?
Maryak said:Arnold,
Thanks for the continued support. :bow:
In a word no.The bore stays as is, (locked up tight), and the whole thing is tapped home using a 1/2 lb hammer and a brass dolly. You soon know if your heavy handed as the housing spins on the mandrel. In this case, maximum facing cut 0.015," maximum longitudinal cut 0.020." Ask me how I know. :
It's also a good idea to start with hand feed IMHO until the preceding is determined.
Edit - If you loosen the bearings you lose concentricity and the fancy round bits on one end will not be round when you take it off the mandrel and re-tighten.
Best Regards
steamer said:Didn't know those parts got welded!....hope they don't move around much.
CrewCab said:Bob, in my very limited experience using electric metal glue welding I would prefer a stick welder with the sections you are working with, penetration is far superior (technical term chaps :) ........ with MIG I find I get an awful lot of build up but naff all penetration ............ OK ........
I know, perhaps best if I start a new thread so experienced folk can tell me what I'm doing wrong![]()
Great thread, though I think I've lost the plot regarding the bearings, ............. I'll go back and read it all again and see if the brain cell kicks in
atb
CC
RobWilson said:Hi CC allot of people fine it hard to set up a MIG , as it can be set up three ways spray transfer, dip transfer and the wrong way.
CrewCab said:no doubt I've been using option 3 then :.............. to be fair I've only done a little welding over the years and it'll be mainly inexperience, once I get the bug again I'll shout up for a little advice if I may Rob ......... thanks in anticipation
CC
