Andy Munns
Sorry for reply length, but a complex subject...
Yes - Condenser vacuum is created ONLY by the collapsing volume of exhaust steam and air harms this vacuum because at these low pressures, air occupies a huge volume.
A condensate or extraction pump (termed by my steam turbine friends) removes condensate only and a separate air extraction pump removes entrained air.
Air enters the exhaust system via rod gland leaks plus air dissolves in open boiler feed water and enters the system. Sometimes larger steam plants have a feed deaerator to remove some of this air - Smaller plants, say <1000 IHP mostly did not.
Most smaller steam recip plants (say < 1200 IHP) tended to have an engine-driven extraction pump, which recip engine engineers called the "air pump" because its largest duty was removing air - The condensate was also removed by the air pump - Condensate was also necessary to lubricate the air pump plus the design of the pump at the head valves form a water seal weir that helped seal against air leaking back. The air was discharged into the engine room while the condensate flows back to the feed pumps via the hotwell or a float tank.
The Stuart triple resembles the smaller high-speed engines that had balanced cranks and shorter strokes commonly fitted to fast launches and naval craft. Search Bolton triple on the other hand - This is based on a Sydney (Au) double-ended ferry engine and resembles more the sort of double column triple fitted to tugs and ferries. Double column engines often did a lot of astern running.
