Hi, cwalk. The test was done. Board ratio 39,999 it didn't work for me (I have the good one 54). After changing the board ratio, it works flawlessly. It is likely that the 1:60 ratio interfered with the original correct step. Round table 1:36 + with belt drive 1:60 ratio.Hello Imre, This is the code which I used. Hope it is useful to you.
Regards Colin
4x4 matrix keypad amd a 20 x 4 LCD.
Edit StepsPerRotation & TableRatio(# of turns for 360 degrees)in line 29
A4988 Stepstick/Pololu driver
5/2/2015
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'.','0','#','D'}
byte rowPINS[ROWS] = {11,10,9,8};
byte colPINS[COLS] = {7,6,5,4};
Keypad kpd = Keypad(makeKeymap(keys),rowPINS,colPINS, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x20 for a 16 chars and 4 line display
// SCL - A5, SDA - A4, VCC - +5, Gnd - Gnd
//setup vars
const int stp = 2; // connect pin 2 to step
const int dir = 3; // connect pin 3 to dir
const int StepsPerRotation = 400; // Set Steps per rotation of stepper NOTE the driver is set to Half step
const float TableRatio = 39.9999; // ratio of rotary table
const float Multiplier = (StepsPerRotation * TableRatio)/360; // 400*39.9999=15999.96/360 = 44.444333
const int stepdelay = 1;
float Degrees = 0; // Degrees from Serial input
float ToMove = 0; // Steps to move
float bob = 0;
int cho = 0;
void setup()
lcd.init(); // initialize the lcd
pinMode(stp, OUTPUT);
pinMode(dir, OUTPUT);
// Print welcome message to the LCD.
lcd.backlight();
lcd.print("Rotary Table Control");
lcd.setCursor(4,2);
lcd.print(" ");
lcd.setCursor(3,3);
lcd.print("updated 2016");
delay(2000);
lcd.init();
cho = 0;
char key = kpd.getKey();
lcd.print("Enter Selection:");
lcd.setCursor(0,1);
lcd.print("Degrees = A");
lcd.setCursor(0,2);
lcd.print("Divisions = B");
lcd.setCursor(0,3);
lcd.print("JOG = C");
while(cho == 0)
key = kpd.getKey();
switch (key)
case NO_KEY:
break;
case 'A':
Degrees=getdegrees();
lcd.clear();
cho = 1;
break;
case 'B':
Degrees=getdivisions();
cho=2;
break;
case 'C':
Degrees=getjog();
lcd.clear();
cho=3;
break;
} // end case
} // end while cho=0
} // end setup
void loop() // MAIN LOOP
lcd.clear();
bob = 0;
lcd.setCursor(7,0);lcd.print("Total: ");lcd.print(bob,2); // total steps
lcd.setCursor(0,3);lcd.print("FOR=A REV=B X=C");
while(key != 'C') // C will return to start menu
lcd.setCursor(0,0);lcd.print(abs(Degrees),2);lcd.print((char)223);
key = kpd.getKey();
if(key == 'A') // FORWARD
bob = bob + Degrees;
ToMove = (Degrees*Multiplier);
digitalWrite(dir, LOW);
printadvance();
if(key=='B') // REVERSE
bob = bob - Degrees;
digitalWrite(dir, HIGH); // pin 13
printadvance();
} // end while not C loop
lcd.init();
setup();
} // end main VOID
float getjog()
float Degrees = 0;
float num = 0.00;
lcd.clear();
lcd.setCursor(6,0);lcd.print("Jogging");
lcd.setCursor(0,1);lcd.print("A=1 B=10 C=100 Steps");
lcd.setCursor(0,2);lcd.print("Enter Degrees:");lcd.setCursor(0,3);lcd.print("OK = # ");lcd.print((char)60);lcd.print((char)45);lcd.print(" D");
while(key != '#')
switch (key)
case NO_KEY:
break;
case 'A':
Degrees = 1;
lcd.setCursor(14,2);lcd.print(Degrees);
break;
case 'B':
Degrees = 10;
break;
case 'C':
Degrees = 100;
break;
case 'D':
num=0.00;
lcd.setCursor(14,2);lcd.print(" ");
break;
key = kpd.getKey();
return Degrees;
float getdivisions()
float Degrees = 0;
float num = 0.00;
lcd.clear();
lcd.setCursor(0,1);lcd.print("Enter Division:");lcd.setCursor(0,3);lcd.print("OK = # ");lcd.print((char)60);lcd.print((char)45);lcd.print(" D");
lcd.setCursor(16,1);
while(key != '#')
switch (key)
case NO_KEY:
break;
case '0': case '1': case '2': case '3': case '4':
case '5': case '6': case '7': case '8': case '9':
num = num * 10 + (key - '0');
lcd.print(key);
break;
case 'D':
num=0.00;
lcd.setCursor(16,1);lcd.print(" ");
break;
Degrees = 360/num;
key = kpd.getKey();
return Degrees; //num;
float getdegrees()
//int key = 0;
float num = 0.00;
float decimal = 0.00;
float decnum = 0.00;
int counter = 0;
lcd.clear();
//lcd.init();
lcd.setCursor(0,1);lcd.print("Enter Degrees:");lcd.setCursor(0,3);lcd.print("OK = # ");lcd.print((char)60);lcd.print((char)45);lcd.print(" D");
lcd.setCursor(15,1);
bool decOffset = false;
while(key != '#')
switch (key)
case NO_KEY:
break;
case '.':
if(!decOffset)
decOffset = true;
lcd.print(key);
break;
case 'D':
num=0.00;
lcd.setCursor(15,1);lcd.print(" ");
break;
if(!decOffset)
lcd.print(key);
else if((decOffset) && (counter <= 1))
lcd.print(key);
counter++;
break;
} //end case
decnum = num / pow(10, counter);
key = kpd.getKey();
} //end while not #
return decnum;
} // end getdegrees
void printadvance() // print function
lcd.setCursor(6,1);lcd.print("Moving");
lcd.setCursor(4,2);lcd.print("Steps ");lcd.print(ToMove,0);
lcd.setCursor(13,0);lcd.print(bob,2);
rotation(ToMove,0);
lcd.setCursor(6,1);lcd.print(" ");
void rotation(float tm, int d)
for(int i = 0; i < tm; i++)
digitalWrite(stp, HIGH);
delay(stepdelay);
digitalWrite(stp, LOW);
delay(stepdelay);
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile (" jmp 0");
Original: const float Multiplier = (StepsPerRotation * TableRatio)/360; // 400*39.9999=15999.96/360 = 44.444333
Own: const float Multiplier = (StepsPerRotation * TableRatio)/360; // 400*54=21600/360=60
Thanks for the help.
