Been busy ,time for update.
Managed to get the material for the crosshead for a song ,downside was its the welded pipe .Also managed to pick up a 4.5" horizontal bandsaw ,got a decent lennox blade in it (thanks johnS) and i am dead chuffed .Was due to cough for a new one when this one came up .It is easier and safer to saw than part off some of these 3" steel bars then face them up in the softies .
Right buisness , cut length of pipe (on new saw :big
clocked it in the 4 jaw ,skimmed the galvo off the exterior and cleared the weld and galvo from the bore ,turned a register on the end .Machined up flange ,with bore to take pipe register .angled the inner bore 20 deg to allow solder to fillet joint.Cut it off(on new saw :big
Silver soldered the 2 halves together ,no worries ,off for a brew while it all cools down.
Bored out the softies and cleaned up the od ,front face of flange,and took the bore to within 1mm of finish .
On with the 4 jaw ,didnt want to muller the end of the part so i cut a small lump of copper pipe split it and fitted on the end and clocked the part up jaws gripping on the copper band .Also found out part too large for my steady Grrrr ! Finish bored the sleeve nice and slow with sharp tool, once done skimmed the mating face of the flange to keep it square with the bore . Inserted a blank centre into the bore c drilled supported with the centre and skimmed the large dia of the flange .Job done went for a brew
